本人研一,上电力电子设计课程最近需要做课程设计。本人背景:没什么项目经验,这是上的第二门电力电子课,只是学完了mohan的power electronics书和erickson 的fundamentals of power electronics。
设计要求如下:
1.design a practical power converter越实际越好
The converter should be stable under feedback control, have appropriate input and output filters, and with components having adequate ratings.
2. Output power 大于12 W.
3. If you design a non-isolated converter, you have two options:
Use peak current control.{
Use voltage mode control but the converter has to operate in discontinuous conduction mode.4.If you design an isolated converter, you can use voltage control, but your feedback signals shouldn break the electrical isolation barrier.
5. All the components in your design must be commercially available.
6.画出电路图而且要layout 通过an automatic DFM (Design For Manufacturability) check.
我现在只是学了书本知识,没有实际动手经验,这次的project也是个很好的锻炼,我就是想请教大家我这个project取材方面的问题,做什么方面的power converter会比较好一点。project的时间是4月中旬结束。所以时间的把握也是一个问题。求助各位电源大虾了!!
