请问中小功率电源设计高手!
请问中小功率电源设计高手!
请问IXYS公司的快恢复二极管DSEI2X101-12A用于电源变压器次边做整流二极管使用时能工作的最高工作频率,有高手在100KHZ以上用过吗?
注:其反向恢复时间为35ns
请高手赐教!!!
全部回复(5)
superpowersupply
That is not a problem,but you‘d better to know that the lower working frequency,the more heat loss,if it can pass the thermal test,you can use it at higher working frequency.
ljq0823
@superpowersupply
Thatisnotaproblem,butyou‘dbettertoknowthatthelowerworkingfrequency,themoreheatloss,ifitcanpassthethermaltest,youcanuseitathigherworkingfrequency.
你的意思是只要散热没问题,可以工作在更改频率?
"you'd better to know that the lower working frequency,the more heat loss"
我有点不明白?
Thank you!!!
superpowersupply
@ljq0823
你的意思是只要散热没问题,可以工作在更改频率?"you'dbettertoknowthatthelowerworkingfrequency,themoreheatloss"我有点不明白?Thankyou!!!
Yes,I think so.
ljq0823
@superpowersupply
Yes,Ithinkso.
请问您实践中应用过它吗?
superpowersupply
@ljq0823
请问您实践中应用过它吗?
35ns is a very short time.
What are you afraid of?
I have not use thins one.
【 DigiKey DIY原创大赛】基于树莓派5B和CSI摄像头的手势控制---项目实操
北葵依旧菜
地瓜patch
基于树莓派的 Modbus 网关制作
pomin
【 DigiKey DIY原创大赛】开源项目 - 恒温加热平台
Jellysplash
AD工程PCB文件导入LCEDA故障问题解决。
程序小白
