請教一個詞組
Bulk loop test
請問一下這個詞組如何翻譯,謝了先
全部回复(1)
topwbs
This option allows to specify a percentage that high speed data loop back tests can pass. For example, /H:80 means if 80% of the data ((number of bytes correctly received)/(total number of bytes transferred)) received are correct, then the test passes.
