请教12864C液晶控制
我是初学者,正在学液晶,找了一块12864C,内控IC未知,找了些相关资料,写了个小程序,只要求能显示,我就是尝试将数写入液晶内,并显示.但液晶几乎没反应,不知为何?
#include
#include
#include
#include
#define   unchar   unsigned char
#define   unint    unsigned int
/*************LCD指令****************/
#define  GLCD_ON       63      //打开LCD
#define  GLCD_OFF      62      //关闭LCD
#define  GLCD_LINE     192     //左半边起始行
#define  SET_PAGE      184     //设置页数
#define  SET_Y         64      //设置Y轴位置
#define  CLEAR         0       //清除LCD
/*************LCD控制****************/
sbit          EN   = P2^7;
sbit          RW   = P2^6;
sbit          RS   = P2^5;
sbit          CS2  = P2^4;
sbit          CS1  = P2^3;
unchar        Gx,Gy;
/***************查忙*****************/
check_GLCD()
  unsigned char x,bei_cs1,bei_cs2;
  bei_cs1=CS1;
  CS1=0;
  bei_cs2=CS2;
  CS2=0;
  EN = 0;
  RW = 1;
  RS = 0;
  P1 = 0xff;
  EN = 1;
  do
    x=P1&0x80;
  while(x);
  EN = 1;
  RW = 1;
  RS = 1;
  CS1=bei_cs1;
  CS2=bei_cs2;
/*********************写入控制指令0/0****************/
void write_GLCD(unsigned command)
  unsigned char bei_cs1,bei_cs2;
  bei_cs1=CS1;
  bei_cs2=CS2;
  EN = 0;
  CS1=0;
  CS2=0;
  RW = 0;
  RS = 0;
  EN = 1;
  P1 = command;
  EN = 0;
  RW = 1;
  RS = 1;
//检查忙碌标志
  check_GLCD();
  CS1=bei_cs1;
  CS2=bei_cs2;
/************初始复位*******************/
clear_GLCD()
  unsigned int i,j;
  for(i=0;i<2;i++);
  CS1=1;
  CS2=1;
  write_GLCD(GLCD_ON);
  write_GLCD(GLCD_LINE);
  for(i=0;i<8;i++)
    write_GLCD(SET_PAGE+i);
    write_GLCD(SET_Y);
    for(j=0;j<64;j++)
      write_GLCD(0);
/*********************写入显示数据1/0****************/
void write_GLCD_data(unsigned GLCDdata)
  bei_cs1=CS1;
  bei_cs2=CS2;
  EN=0;
  CS1=0;
  CS2=0;
  RW=0;         // P2_6 = 0
  RS=1;         // P2_5 = 1
  EN=1;         // P2_7=1
  P0=GLCDdata;  // 从 P0 送出 数据
  EN=0;         // P2_7= 0
  RS=0;         // P2_5 = 0
  RW=1;         // P2_6 = 1
// 检查忙碌标记,直到绘图型LCD不忙碌时就返回
  check_GLCD();
  CS1=bei_cs1;
  CS2=bei_cs2;
/*********************读显示数据****************/
read_GLCD()
  unsigned char bei_cs1,bei_cs2,command;
  bei_cs1=CS1;
  bei_cs2=CS2;
  EN = 0;
  CS1=0;
  CS2=0;
  P1=0xff;
  RW = 1;
  RS = 1;
  EN = 1;
  command = P1;
  EN = 0;
  RW = 1;
  RS = 1;
//检查忙碌标志
  check_GLCD();
  CS1=bei_cs1;
  CS2=bei_cs2;
  return  command;
gotoxy(unsigned x,unsigned y)
  Gy=y;
  Gx=x;
/*****************主程序区****************************/
main()
  unsigned int       j,n;
  unsigned char      c2,c3;
  while(1)
    clear_GLCD();
    gotoxy(0,0);
    write_GLCD(1);     //设置x  3F/63     GLCD_ON
    write_GLCD(GLCD_LINE);   //  C0/192
    for(c2=0;c2<4;c2++)
      write_GLCD(SET_PAGE+c2);       //184
      write_GLCD(SET_Y);              //64
      for(j=0;j<64;j++)
        write_GLCD(64+j);
        write_GLCD_data(j);
        c3=read_GLCD();
      c3=read_GLCD();
    EN=1;
    CS1=0;
    CS2=0;
    EN=0;
    for(n=0;n<50000;++n);
1044201183705432.sch
全部回复(4)
xing1234
电源是工作正常了的,能看见底色,负压也调好(大约-5.5V),我正在带起仿真器努力调试.
xing1234
@xing1234
我找的12864C资料, 1044201183779653.pdf
xiaojia
12864 pdf
@xing1234
我找的12864C资料,1044201183779653.pdf
嘻嘻,好东西!!thank you!
