看到这样一句话:
it dose not cause ground bounce problem
里面的ground bounce problem是什么意思?
哪位知道,请说一下,谢谢!
怎么翻译?
全部回复(9)
@hereliu
地弹躁声
多谢!还有下面两句不太懂,麻烦帮我看看吧!
1.The turn-off transistor shunts out the gate drive loop inductance, the potential current sense resistor, and the output impedance of the driver. 里面的shunts out 和 potential current sense resistor
2.the gate of the main MOSFET is floating before the outputs of the driver IC becomes intelligent during power up.里面的becomes intelligent during power up
谢谢!
谢谢!
@ziling
多谢!还有下面两句不太懂,麻烦帮我看看吧!1.Theturn-offtransistorshuntsoutthegatedriveloopinductance,thepotentialcurrentsenseresistor,andtheoutputimpedanceofthedriver.里面的shuntsout和potentialcurrentsenseresistor2.thegateofthemainMOSFETisfloatingbeforetheoutputsofthedriverICbecomesintelligentduringpowerup.里面的becomesintelligentduringpowerup谢谢!
难啊.我也看不懂.把电路传上来,或许能猜出来.shunt out 可能指并联.potential current sense resistor 可能指磁化电流感测电阻.第二句大概指,上电期间,在驱动IC的输出变得智能化之前,主MOS的栅极是浮置的.这个intelligent 估计指能够自动控制吧.我只能瞎猜了.
@hereliu
难啊.我也看不懂.把电路传上来,或许能猜出来.shuntout可能指并联.potentialcurrentsenseresistor可能指磁化电流感测电阻.第二句大概指,上电期间,在驱动IC的输出变得智能化之前,主MOS的栅极是浮置的.这个intelligent估计指能够自动控制吧.我只能瞎猜了.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/25/1105150466.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/25/1105150492.jpg');}" onmousewheel="return imgzoom(this);">
第一个图对应第一句话,第二个对应第二句.请你再看一下.谢谢!
@hereliu
不好意思发错了,第二个图是下面这个:500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/25/1105151068.jpg');}" onmousewheel="return imgzoom(this);">
@ziling
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/25/1105150466.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/25/1105150492.jpg');}"onmousewheel="returnimgzoom(this);">第一个图对应第一句话,第二个对应第二句.请你再看一下.谢谢!
第一句的意思应是这样的:(当Qoff导通时),它就把驱动回路电感,驱动器的输出阻抗,及potential current resistor给旁路掉了,(使得关断速度边快了).potential current resistor你没画出来,估计是磁化电流传感电阻.第二句就是我说的哪个意思,及上电期间,芯片还未开始工作,没有输出时,MOS栅极是浮置的.
