SP3413/SP3406同步整流车充方案
SP3413车充方案  刘云 18603037844  QQ:735300416
SP3413 has an optimum input voltage, step-down converter that operates in either CV (Constant Output Voltage) mode or CC (Constant Output Current) mode. The maximum input voltage is up to 42V and the operation input voltage from 7.5V to 32V.
 MOSFET, what build in 35mΩ High-Side and 25mΩ Low-Side, could deliver up to 3.5A of continuous output current and the output current accurate to within ±7%. No external compensation component requirement. The line compensation and the constant current can be set by an external resistance. Independent output voltage protection suits for BC1.2 and QC2.0/3.0 dual channel output voltage. In conclusion, SP3413 is a full function and high performance, high reliability buck DC-DC converter.
nFEATURES
100% Duty Cycle Car Charge Scheme
Build in High-Side and Low-Side MOSFET
Max Output Current: 3.5A
Adjustable Output Voltage, VFB=1.0V
Excellent Constant Current Accuracy: ±7%
Constant Voltage Accuracy: ±2%
Jitter Function
Efficiency: Up to 95%
Adjustable Line Compensation
 Short Circuit Protection
Over Voltage Protection
 Thermal shutdown Protection
Under Voltage Lock Output
Available in SOP-8L Package
全部回复(1)
xpzyzh
如有需要,可联系:李女士 18312586557/QQ3266867360
长期现货供应,提供样品、DEMO板。
