at电源故障~
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/27/1110210724.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/27/1110210735.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/27/1110210743.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/27/1110210750.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/27/1110210756.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/27/1110210762.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/27/1110210767.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
真的麻烦,接通220后风扇不转,电源不启动./关掉220后,电源内部发出"次"的一声响后电源扇转动一下.主板风扇仍不转,但是,要将这个电源放很长一段时间后.它仍可以工作,只是关掉,在短时间内再打开,就出现不启动现象~,
怎么回事?哪个件坏掉了?请各位达人帮帮我~~
全部回复(16)
dengly
看看是不是每组电压都正常,应该是过压或欠压保护了或者是缺少一组电压
電源有帶載嗎?可能是你的電源放電太慢,放久後,電放完了就可以開機了,關掉AC後量它是否還存有殘余電壓,如果有,再跟你電源的重置電源比較大概就知道是什麼原因了
yangxf
应该是短路保护或某电容漏电
gogo991
@dengly
一组电压是只哪一组啊??
gogo991
@电子负载828ate
有带载啊,插在主板上了.
是要我关掉电源后量一下所有电容的电压吗?
gogo991
@yangxf
应该是短路保护或某电容漏电
什么东西可以短路保护呢?
@yangxf
应该是短路保护或某电容漏电
建義你還是將你的機子拿到維修方去會比較好,不然修不好反把其它的零件搞壞了!
gogo991
哈哈,这电源就是从维修的地方"借"出来的!
不自己搞搞怎么会学到呢?
钱谁都会花.可是花过后什么东西都学不到不是白花?
我也是工作需要才搞这些东西的.
师傅们也经验把一个电源搞的"叭叭"响嘛~~
gogo991
@gogo991
哈哈,这电源就是从维修的地方"借"出来的!不自己搞搞怎么会学到呢?钱谁都会花.可是花过后什么东西都学不到不是白花?我也是工作需要才搞这些东西的.师傅们也经验把一个电源搞的"叭叭"响嘛~~
我现在又发现一个1000uF 10V的电容不放电.不知道是不是这个家伙的问题.每次关机的时候只要将这个电容人工放电便可以重新开机.如果没有这个电容可否用一个1000uF 25V的电容代替呢??
eprom681
@gogo991
我现在又发现一个1000uF10V的电容不放电.不知道是不是这个家伙的问题.每次关机的时候只要将这个电容人工放电便可以重新开机.如果没有这个电容可否用一个1000uF25V的电容代替呢??
不放电并不代表它有问题,如果它是电源滤波电容的话给它加个放电电阻就ok,如果不是电源滤波电容就另当别论了
@gogo991
如果是這樣子,那我再同你提一點建義:
第一:你要去了解一下開關電源的基本原理;
第二:你要看一下你的電源所用的主ic是什么;
第三:你再發出你的問題,我們才可以同你作分析與你參考.
這樣子才可能對你有所收益.
gogo991
@eprom681
果真是这样的.
我换上一个1000uF 25V的新电容它仍然不放电..
真的不是这个电容的问题.
gogo991
如果是這樣子,那我再同你提一點建義:第一:你要去了解一下開關電源的基本原理;第二:你要看一下你的電源所用的主ic是什么;第三:你再發出你的問題,我們才可以同你作分析與你參考.這樣子才可能對你有所收益.
嗯.谢谢楼上这位师兄了.
可是哪里有开关电源的基本知识呢?
我的电源IC是DBL494 我已经帖到上面的图上啦?
多谢建议~
菠萝蜜
@gogo991
你的电源应该是典型的AT电源,1000uF的电容必是输出滤波电容无疑,
10V表示其肯定是+5V或-5V的输出滤波电容.查查对应的假负载,我想多是
假负载开路了.
菠萝蜜
@gogo991
嗯.谢谢楼上这位师兄了.可是哪里有开关电源的基本知识呢?我的电源IC是DBL494我已经帖到上面的图上啦?多谢建议~
是的,AT电源原理图很难找,不过一般也就是采用494和339的,功能同出
一辙.原理也一样,甚至元件都差不多.好一点的使用EE35或EI35的磁芯,
TO3P的开关管,输出电容大些(+5V为2200uF或3300uF,+12V为1000uF);
而有的很小气,使用13005的开关管,+5V的滤波电容为1000uF,还标
称250W,我实测只有120W.
gogo991
@菠萝蜜
是的,AT电源原理图很难找,不过一般也就是采用494和339的,功能同出一辙.原理也一样,甚至元件都差不多.好一点的使用EE35或EI35的磁芯,TO3P的开关管,输出电容大些(+5V为2200uF或3300uF,+12V为1000uF);而有的很小气,使用13005的开关管,+5V的滤波电容为1000uF,还标称250W,我实测只有120W.
多放了,我真的很佩服你对AT电源如此之了解.
如果有一日,我能达到你的五分之一,
我想我对目前的工作就已经能得心应手了.
我目前正在一步一步检查,
虽然没有头续,但听了你的话终于感到有些头续了~~..
