3525低频-PIC驱动,频率脉宽可调25-75%成功完全
3525工作低频,推MOS2907 6对陈列安装,由PIC芯片控制3525频率脉宽可调25-75%,无磷/有磷一体机两用设计,程序可升级支持在线下载更新.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/179431235062454.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/179431235062463.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/179431235062474.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/179431235062480.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
该机设计为2KW左右,船用.
全部回复(18)
kelian
我自个先顶一下,,呵呵500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/179431235062977.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/179431235062986.jpg');}" onmousewheel="return imgzoom(this);">
顶完了谢了,,呵呵
QQ35919694超创作品,
yitt
@kelian
我自个先顶一下,,呵呵[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/74/179431235062977.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/74/179431235062986.jpg');}"onmousewheel="returnimgzoom(this);">顶完了谢了,,呵呵QQ35919694超创作品,
牛!高科技啊!
@yhliang2
引用:《3525工作低频,推MOS29076对陈列安装,由PIC芯片控制3525频率脉宽可调25-75%,无磷/有磷一体机两用设计》~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~问题:1》??3525工作低频?  几赫芝?  3525不可能推MOS2907工作在20赫芝诱捕无鳞鱼.  因为3525工作频率低于100hz就不稳定,tl494也只能最低下限到40hz.再低频率就不可能了.2》??  由PIC芯片控制3525频率脉宽可调25-75%??  请问3525频率脉宽可调是怎样实现的?频率变化了后面的变压器的电感阻抗及输出线圈的V/A匝数比怎样解决?整机效率问题怎样解决?频率改变输出阻抗失配烧机问题怎样解决?  特别是25-75%脉宽调宽问题在3525上是是怎样调的?3525是可以调宽的,但3525只是振荡推动,后面还有输出、变压器部分等、等部分.  这调宽能在“振荡”级调吗?即使调了这变压器变成反接工作,功率管变成单边工作,逆程高反压升高,不烧机才怪了.  呵呵.3》??根据楼主上的图一目了然,只是一个纯交流机.里面空空无物,几个另件曲指可数.  所谓“二用、可调”的功能估计也同机箱内一样:空空如一,  输出功率《20赫芝》2kw水份十足.变压器绕制非常“瘦”身.  典型的大铁芯小线包产品.这样的变压器真实的低频功率能有几瓦?
有点同意楼上,针针见血,那变压器最多去到500W,2000W的话是无法实现的.
yhliang2
引用:
《3525工作低频,推MOS2907 6对陈列安装,由PIC芯片控制3525频率脉宽可调25-75%,无磷/有磷一体机两用设计》
问题:
1》?? 3525工作低频?  几赫芝?  3525不可能推MOS2907 工作在20赫芝诱捕无鳞鱼.
   请问3525频率脉宽可调是怎样实现的? 频率变化了后面的变压器的电感阻抗及 输出线圈的V/A匝数比怎样解决? 整机效率问题怎样解决?频率改变输出阻抗失配烧机问题怎样解决?
   特别是25-75%脉宽调宽问题在3525上是是怎样调的? 3525是可以调宽的,但3525只是振荡推动,后面还有输出、变压器部分等、等部分.  这调宽能在“振荡”级调吗? 即使调了这变压器变成反接工作,功率管变成单边工作,逆程高反压升高,不烧机才怪了.  呵呵.
3》?? 根据楼主上的图一目了然,只是一个纯交流机.里面空空无物,几个另件曲指可数.
hbzjcjw
@yhliang2
你错了,3525可以用外加震荡的方法来搞低频率,调占空比.
不过楼主那机明显没有这个功能
yhliang2
@hbzjcjw
你错了,3525可以用外加震荡的方法来搞低频率,调占空比.不过楼主那机明显没有这个功能
外加震荡的方法来搞低频率,调占空比必须在变压器后面有整流滤波后才可以得到《解调制》.
上面楼主并没哪么说,图片中也没有这类作用的另件.所以外加震荡的说法对该机不成立.
3525手册中下限频率是100hz,实践中下限频率也始终达不到50hz.何况电无鳞鱼是20hz.不知楼主用什么方法实现.
kelian
@yhliang2
外加震荡的方法来搞低频率,调占空比必须在变压器后面有整流滤波后才可以得到《解调制》.上面楼主并没哪么说,图片中也没有这类作用的另件.所以外加震荡的说法对该机不成立.3525手册中下限频率是100hz,实践中下限频率也始终达不到50hz.何况电无鳞鱼是20hz.不知楼主用什么方法实现.
很感谢以上楼主的回贴,,呵呵
我能用3525我肯定会明白它不能工作于100HZ以下不稳定工作
那我可以用外部芯片控制它啊,,将3525主频工作在正常的频率,用外部PIC控制它分割它100HZ成低频1HZ都可以.这是原理当然效率就在于3525主频,频率不低当然效率就不会低了.
就是书生和劳动者还是有一定分别的500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/179431235295535.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/179431235295565.jpg');}" onmousewheel="return imgzoom(this);">
不能实现它的功能,那机是吹出来不是做出来,,呵呵
kelian
@kelian
很感谢以上楼主的回贴,,呵呵我能用3525我肯定会明白它不能工作于100HZ以下不稳定工作那我可以用外部芯片控制它啊,,将3525主频工作在正常的频率,用外部PIC控制它分割它100HZ成低频1HZ都可以.这是原理当然效率就在于3525主频,频率不低当然效率就不会低了.就是书生和劳动者还是有一定分别的[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/74/179431235295535.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/74/179431235295565.jpg');}"onmousewheel="returnimgzoom(this);">不能实现它的功能,那机是吹出来不是做出来,,呵呵
说到功力问题,不记得补一个图
功力可以上到2KW实际负载,上图是试验,最大可以达到让输入电流超200A
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/179431235295908.jpg');}" onmousewheel="return imgzoom(this);">
yhliang2
@kelian
说到功力问题,不记得补一个图功力可以上到2KW实际负载,上图是试验,最大可以达到让输入电流超200A[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/74/179431235295908.jpg');}"onmousewheel="returnimgzoom(this);">
确实有芯片支持,但是否能出20hz不一定.因为二次图片未证实有解调制另件.
kelian
@yhliang2
有道理,,可呵
只能现场调才能正实,,呵呵...视频也有假的
@kelian
这样一来,不就是传说中的混频么。
hbzjcjw
@中金黄金
这样一来,不就是传说中的混频么。
QQ28890451
@hbzjcjw
不太信啊!这变压器有2000W?如果是高频的磁芯我连10000W都信,这?我是很相信啦!我的那个500VA的都快10斤重啦!
@QQ28890451
2000w有没有不敢说,但是你说500w要10斤重也是有点夸张(一般低频鱼机频率大多数在120hz~240hz之间,没有后级直接输出)。
hbzjcjw
@QQ28890451
这个你不要抬杠,频率做到800HZ绝对不止2KW
@kelian
plc??鱼机都搞起自动化了
自动化鱼机。高啊!
@873908152
自动化鱼机。高啊!
当年吹过现在还有人在论啊,,呵呵。。。这么久了现在也顶一下
