闲着没事,做个工频家用逆变器
最近不忙,用UPK2436和5对3205做了一个50HZ工频逆变器以备停电应急.变压器和外壳是监控专用电源改的,空载电流2A(有点大).空载输出电压250V,输入用空气开关做过流保护,输出用继电器做短路保护.由于电瓶是旧的接上400W灯,电瓶电压只有11V,下面是效果图.500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/76/1251211239349760.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/76/1251211239349766.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/76/1251211239349774.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/76/1251211239349781.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(33)
瑞星
呵呵,这古董我也有一块,在N年前邮购的500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/76/2787961239351112.jpg');}" onmousewheel="return imgzoom(this);">
tby2008
@瑞星
呵呵,这古董我也有一块,在N年前邮购的[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/76/2787961239351112.jpg');}"onmousewheel="returnimgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/76/1380241239353222.jpg');}" onmousewheel="return imgzoom(this);">
@瑞星
效果还是不错的
yezhiyuan
这个不可以做稳压啊用3524或者3525做还可以稳压,不过还是多谢楼主跟大家分享成果
zxc789
@yezhiyuan
用3525做的话,空载电流可能没有这么大
AIBA90000
有没有原里图!变压器变比是多少!初级多少负?
@AIBA90000
我也做了个,空载电流很大有4A多,用环形的2A多,假如频率加大到200HZ的话空载电流就下降到200MA,但带电风扇很不爽,后改用桥式逆变,空载电流比较小,但数字万用表测SG3525 11,14脚频率60HZ,但测桥那边的频率很高达到120多不知道怎么回事?那位大侠知道为什么?
我也做了个,空载电流很大有4A多,用环形的2A多,假如频率加大到200HZ的话空载电流就下降到200MA,但带电风扇很不爽,后改用桥式逆变,空载电流比较小,但数字万用表测SG352511,14脚频率60HZ,但测桥那边的频率很高达到120多不知道怎么回事?那位大侠知道为什么?
我也是这样的问题啊!
AIBA90000
我用UPK2436和20个3DD15D做了个逆变器!但接通电源灯泡亮2秒钟就不亮了!但变压器有点声音,不过没灯泡亮着时响!也就是说应该还是起振的!但电压只要十几伏,而且一直接通电源1分钟变压器和管子都很热,烫手!这是怎么回事!
@AIBA90000
变压器磁饱和
ggjiazhu
小弟是个菜鸟请高手帮帮忙,电镀电源用三菱IGBT模块漏电 问题出在哪?加我QQ:674739101
AIBA90000
@pirate000000
变压器磁饱和
我用的环形变压器可能是此饱和了!还有个问题!就是我的管子两边有点温差!担不是太多!这是什么问题长时间用有问题么!         我用场管3205怎么不能震荡!能给我个3205的图么!
@AIBA90000
电源网上图不是很多吗?自己找一下,振荡电容用0.1UF电阻130KR试一下
AIBA90000
我也是用的UPK2436做的!因为这是个老古董,现在这个模块的电路图很少!我是用这个图改了一下但不能起振,不知道那里问题! 还有就是变压器饱和的问题,能不能不在变压器上不开气隙的情况下怎么让变压器不饱和!增加扎数我已经试过了!不管用!
@AIBA90000
我也是用的UPK2436做的!因为这是个老古董,现在这个模块的电路图很少!我是用这个图改了一下但不能起振,不知道那里问题![图片] 还有就是变压器饱和的问题,能不能不在变压器上不开气隙的情况下怎么让变压器不饱和!增加扎数我已经试过了!不管用!
环变对驱动信号两边轻微不平衡很敏感,最好用E变
AIBA90000
@xzszrs
那能不能先用一个EI变压器逆变!然后在用环形变压器来升压~!
@AIBA90000
我觉得没这个必要,要不你环变用桥接方式,我就是弄不懂,我的11.14脚输出明明是60HZ,但经过桥后却有120HZ
AIBA90000
把你的图纸传份给我看下!如果行我也试着做个,你的最大功率能到多大???
要想空载小,效率高,就做高频的。
@AIBA90000
你参考一下HBZJCJW的全桥逆变器吧
QQ28890451
@ggjiazhu
小弟是个菜鸟请高手帮帮忙,电镀电源用三菱IGBT模块漏电问题出在哪?加我QQ:674739101
你是只测14或11一个脚?先问下您知道什么叫推挽先?不是2个线圈轮流通电吗?那就是2个管是轮流工作的,那么一个工作是60HZ的,2个交替工作时,每个60HZ加起来等于120HZ也是正常啊!只要把11和14脚频率调为25-30,高压输出就是50-60喇嘛!对不对?建议把震荡电阻改成可调电阻,方便调试,调好后就加热熔胶粘紧,我也是一样的!
@瑞星
 这是我的UPS做的,和你那块是兄弟.效果很好.晒一下
zhaisiqi
@xzszrs
要想空载小,效率高,就做高频的。
请教钟工:12V1000W高频逆变器,带两个散热风扇空载电流有950mA左右,是否正常?另外满载时好像散热不是很好,该装多大的散热片合适呢?前级4个变压器,8只IRF1010,后级8只IRF740,整流管500瓦就很烫了,是HER605,6A的,是不是有点小了?
@xzszrs
要想空载小,效率高,就做高频的。
高频空载电流小,效率高,但相对工频来说复杂,并且工频的过载能力强,难烧场管,便于业余条件制作,不需要电路板搭焊也能做成,当然效果比做得好的差一些。多谢您送的管子
AIBA90000
UPK2436和3205应该怎么接,那位知道接线图,和电阻取值!
@AIBA90000
把接线图和电阻取值给  顶 出来
浪子qiu
建议做高频的,高频的重量轻,效率高
@浪子qiu
建议做高频的,高频的重量轻,效率高
高频逆变家用很容易坏,还会损坏电器,一句话水平不高很难搞定。
@zhaisiqi
4个变压器空载正常,整流管最好用TO-220的860之类装上散热片。
wyjwyj08
2010-12-21 16:41
@瑞星
呵呵--------这逆变模块我也有2块,也是前年邮购,一直没用,不过带回来家去了,有机会我也拿来DIY下--呵呵--------------不知道这2436输出是什么波??
