大家好,
这里有个问题想请教大家,我用了TI公司的UC2891作了一块电源,是有源钳位的顺向式电源,遇到了一个问题,输出负载比较轻的时候,可以实现零电压开关,但是负载加大时,会出现主开关管开启是无法过零转换,附有图片一张.
CH1, MAIN MOSFET DRIVER,
CH2, MAIN MOSFET VDS,
CH3, AUX MOSFET VDS,
CH4, CURRENT WAVEFORM OF Ids(Main mosfet),
我是刚到这里来的,希望大家多多指教.
谢谢!
TOM1147163487.pcx1147163510.pcx1147163699.pcx
有源钳位的顺向电源设计
全部回复(32)
@jacki_wang
Itshouldhaveabalancingpointforthebestefficiency.
yeah, but the efficiency still keep in 86-89%,so I wanna give up using this topology, so do you have some good ideas for the Sepic topology, I wanna use this to replace the traditional pfc circuit and using the LLC to be the dc-dc module.
the target of efficiency is 90% total.
@t168_tao
Iamquitesorryaboutthis,theconditionasbelow,input90-264vac47-440Hzoutput12v/8Awithplasticencloser,thicknessis3mm,sizeis2"x4"1.5"(WxLxH),itisdifficulttotransfertheheatthroughencloser.
I had never design the PFC with sepic topology, the advantage of sepic seems can not help you for the very high efficiency, and LLC is not very suit for wide bulk range, maybe use the two step voltage for PFC and add SR with active clamp can achieve your efficiency requirement.
@jacki_wang
IhadneverdesignthePFCwithsepictopology,theadvantageofsepicseemscannothelpyoufortheveryhighefficiency,andLLCisnotverysuitforwidebulkrange,maybeusethetwostepvoltageforPFCandaddSRwithactiveclampcanachieveyourefficiencyrequirement.
you think me wrong, current desian is pfc+ active clamp with sync rectifier, due to the low efficiency of active clamp, total efficiency can't meet the requirement,
and if use tow step pfc circuit, it is difficult to design the active clamp stage.
so, I decide use Sepic to replace the frist stage to provide stable bulk voltage, about 250vdc, and use LLC to achieve the dc-dc stage.
@t168_tao
youthinkmewrong,currentdesianispfc+activeclampwithsyncrectifier,duetothelowefficiencyofactiveclamp,totalefficiencycan'tmeettherequirement,andifusetowsteppfccircuit,itisdifficulttodesigntheactiveclampstage.so,IdecideuseSepictoreplacethefriststagetoprovidestablebulkvoltage,about250vdc,anduseLLCtoachievethedc-dcstage.
You can try to separate the efficiency of PFC and PWM stage and then you can get the way to improve the efficiency.
@jacki_wang
Yes,uaright,butthereisonethinkmayneedtocare,thevariationfrequencyofLLCisnotsuitforusingSR,theefficiencystillhardtoimprove,isitright?
that is the key point why I use the Sepic, I wanna use this special topology to adjust the bulk voltage and set the LLC at the stable frequency,
So, the way to get stable output is to control the duty cycle of Sepic. no need the variable frequency to control.
@t168_tao
thatisthekeypointwhyIusetheSepic,IwannausethisspecialtopologytoadjustthebulkvoltageandsettheLLCatthestablefrequency,So,thewaytogetstableoutputistocontrolthedutycycleofSepic.noneedthevariablefrequencytocontrol.
Good idea, please also consider how to achieve the hold up time if needed.
@t168_tao
hi,jacki,Doyouhaveanygoodideas,mycurrentprojectisveryurgent,needyourhelp.
If there is very urgen schedule, new topology is not prefer, it will waste a lot of time.
Sorry no idea to get 90% efficiency at worst case, if you had got 89%, I'll prefer to do the optimization from current topology, active clamp can meet wide range, the main concern is the drive voltage of SR, and if you can solve this issue, the winner is you!
Using low loss material is also the way to improve the efficiency, and optimize the component value also help.
Does the heat make you to design for such high efficiency? or it is customer requirement?
@jacki_wang
Ifthereisveryurgenschedule,newtopologyisnotprefer,itwillwastealotoftime.Sorrynoideatoget90%efficiencyatworstcase,ifyouhadgot89%,I'llprefertodotheoptimizationfromcurrenttopology,activeclampcanmeetwiderange,themainconcernisthedrivevoltageofSR,andifyoucansolvethisissue,thewinnerisyou!Usinglowlossmaterialisalsothewaytoimprovetheefficiency,andoptimizethecomponentvaluealsohelp.Doestheheatmakeyoutodesignforsuchhighefficiency?oritiscustomerrequirement?
yeah, the heat froces me to get higher efficiency, and the 89% efficiency is only for dc-dc, pfc stage's efficiency is only 93%( working at ccm mode, because there isn't enought space to layout emi filter). so the total efficiency is about 82.7%.
there is a very long distance to the target.
@t168_tao
yeah,theheatfrocesmetogethigherefficiency,andthe89%efficiencyisonlyfordc-dc,pfcstage'sefficiencyisonly93%(workingatccmmode,becausethereisn'tenoughtspacetolayoutemifilter).sothetotalefficiencyisabout82.7%.thereisaverylongdistancetothetarget.
Hard switch and diode can acheave 82% easily, why you only can got such low efficiency?
@jacki_wang
Hardswitchanddiodecanacheave82%easily,whyyouonlycangotsuchlowefficiency?
I don't think so, to get a high efficiency is very difficult, as we know, for ccm pfc, maybe 93% eff is very good, and for dc-dc stage, 89% is also quite high, but the total efficiency equals to 89*93%, so I need to improve the effuciency of dc-dc stage.
@t168_tao
Idon'tthinkso,togetahighefficiencyisverydifficult,asweknow,forccmpfc,maybe93%effisverygood,andfordc-dcstage,89%isalsoquitehigh,butthetotalefficiencyequalsto89*93%,soIneedtoimprovetheeffuciencyofdc-dcstage.
ZCS PFC+3842 can get 83% at 90Vac and 12V/8.3A output,so 82% for active clamp seems not reasonable?
@jacki_wang
ZCSPFC+3842canget83%at90Vacand12V/8.3Aoutput,so82%foractiveclampseemsnotreasonable?
hi, jacki,
There are two circuits confused me, our current design used active clamp and active pfc, and it's efficiency achieves about 86.4%, but we have got 84.5% eff on our original product used general topology flyback. the difference is current design is output 60W(5v/12A), and previous one is 60W/(12v/5a).
Can you tell me the root cause, and could u please give me some good advice on pfc design,
Regards,
tom
Regards,
tom
@t168_tao
hi,jacki,Therearetwocircuitsconfusedme,ourcurrentdesignusedactiveclampandactivepfc,andit'sefficiencyachievesabout86.4%,butwehavegot84.5%effonouroriginalproductusedgeneraltopologyflyback.thedifferenceiscurrentdesignisoutput60W(5v/12A),andpreviousoneis60W/(12v/5a).Canyoutellmetherootcause,andcouldupleasegivemesomegoodadviceonpfcdesign,Regards,tom
sure the 5V/12A will have more loss with same topology, but you got higher efficiency with active clamp, means you choise the better topology, but the higher efficiency maybe caused by the SR, that you need to clarify.
I think the ZCS PFC should suit for 60W power level design.
@jacki_wang
surethe5V/12Awillhavemorelosswithsametopology,butyougothigherefficiencywithactiveclamp,meansyouchoisethebettertopology,butthehigherefficiencymaybecausedbytheSR,thatyouneedtoclarify.IthinktheZCSPFCshouldsuitfor60Wpowerleveldesign.
I think so, here is a good news for you, now, pfc stage can get 95% efficiency. so total efficiency will be 88%, it is close to our target.
Yet, I need to optimize dc-dc stage, because there are lot of disadvantages I found during prototype stage.
