【问】TI的ATCA解决方案
TI芯片公司在电源方面已经设计到各个领域,从照明到工业领域等都有自己的解决方案,不仅仅是做芯片,解决方案越来越多,TI是否有ATCA供电解决方案?
全部回复(9)
javike
LV.12
TI有ATCA的解决方案,具体信息可以看官网介绍:http://www.ti.com.cn/solution/cn/atca_solutions
awg360
可詳見T1官方網:http://www.ti.com.cn/solution/cn/atca_solutions
高级电信计算架构 (ATCA) 解决方案
@awg360
可詳見T1官方網:http://www.ti.com.cn/solution/cn/atca_solutions高级电信计算架构(ATCA)解决方案
这种供电为什么需要做一个单独的方案呢。
javike
LV.12
@zhanghuawei
这种供电为什么需要做一个单独的方案呢。
需要支持热插拔
zhc7302
@javike
1、框图
2、注意事项
Advanced Telecom Computing Architecture (ATCA) Solutions can be divided by the zones as defined in the ATCA PICMG 3.0 open standard
Zone 1:
Has specific requirements for delivering dual redundant -48V power feeds to individual boards which may consume up to 200W each. ATCA defines many requirements which are typical for a modern, hot swapped power system. The core subsystems include:
  • 48V Hot Swap operates with wide range of negative voltage to optimize power management for use in nominal -48V systems.
  • Isolated Supply consists of power management devices generating the intermediate voltage for the supply bus.
  • AMC Hot Swap controller generates power to Advanced Mezzanine Cards. additional information
  • Non-Isolated module consists of DC/DC Converters generating the on-board primary voltage supply.
  • The Power Supply block consists of Buck/Boost Converters, Controllers, LDOs and Power Management Units to supply power to various functional blocks. These functions can be realized by Digital Power devices.
The IPMC (Intelligent Platform Management Controller) supports the card management, It consists of a MCU like the MSP430 that accepts the inputs from temperature and other sensors and processes the information for the shelf management. The I2C-protocol is used for communication. It controls LEDs that indicate Power-Up, Power-Down and Stand-by modes.
Zone 2:
Is used for data transport and consists of four interfaces:
  • Base Interface is supported by GbE/XAUI or Ethernet PHYs. Backplane connections are always configured in Dual Star Topology.
  • Fabric Interface supports a data rate of up to 3.125Gbps. Differential signaling is used to reduce the common mode noise. Topologies such as dual star or full mesh among all the boards give a large amount of flexibility.
  • Update Channel Interface provides a data rate of up to 2.5Gbps and comprises of 10 differential signaling pairs in a point to point connection between two boards using OC-48 devices as an example.
  • Synchronization Clock Interface manages the clocking of various devices in the card. There are three discrete frequencies specified by the standard: 8kHz, 19.44 MHz and a user defined frequency <100MHz. TI’s clocking solutions provide low jitter and high performance for ATCA applications.
Zone 3:
Is application specific. It generally consists of Advanced Mezzanine Cards (AMCs) which have a DSP, CPU, FPGA or an ASIC embedded to perform specific tasks. An example payload is shown in this block diagram where the PCIe switch routes the information and a PCI to PCIe bridge is used for compatibility. RS-232 and USB serve as external interfaces.
@javike
需要支持热插拔
知道啦
zvszcs
LV.12
@javike
需要支持热插拔
来晚了,都回答了
@zvszcs
http://www.ti.com.cn/solution/cn/atca_solutions来晚了,都回答了
晚了我也来混个铁牌,
不知道晚了楼主是否颁奖啊
lph521
@zhanghuawei
晚了我也来混个铁牌,[图片]不知道晚了楼主是否颁奖啊
学习了,顶贴,是晚了也颁奖
