小麦大叔
认证:普通会员
所在专题目录 查看专题
基于CubeIDE快速整合FreeRTOS创建第一个任务
【FreeRTOS学习02】源码结构/数据类型/命名规则总结
【FreeRTOS学习03】Task Management 任务管理基本概念介绍
【FreeRTOS学习04】Queue Management 消息队列使用详解
【FreeRTOS学习05】深度解剖FreeRTOSConfig.h实现对系统的自定义剪裁
【FreeRTOS学习06】深度解剖中断与任务之间同步的具体使用场景
作者动态 更多
新手学STM32的话,先学标准库还是HAL库?
10-18 15:09
一个超级实用的源码阅读小技巧
07-31 10:28
Sourcetail 一款代码编辑神器,让看源码如丝般顺滑
07-30 09:24
真正的机器人为什么都需要SLAM?
07-29 13:12
又踩坑了!这次败给CAN总线了
07-16 13:59
1 前言
任务之间的同步(同步就是任务之间做数据交互,或为两个任务之间的通讯),任务和中断之间的同步都可以依靠消息队列,从而实现异步处理,FreeRTOS的队列采用FIFO(先进先出)缓冲区,具体如下图所示;
2 xQUEUE
FreeRTOS消息队列的实现主要是queue.c,需要包含头文件queue.h,下面先看一下queue.c中的数据类型xQUEUE,源码如下所示;
typedef struct QueueDefinition
	int8_t *pcHead;					/*< Points to the beginning of the queue storage area. */
	int8_t *pcTail;					/*< Points to the byte at the end of the queue storage area.  Once more byte is allocated than necessary to store the queue items, this is used as a marker. */
	int8_t *pcWriteTo;				/*< Points to the free next place in the storage area. */
	union							/* Use of a union is an exception to the coding standard to ensure two mutually exclusive structure members don't appear simultaneously (wasting RAM). */
		int8_t *pcReadFrom;			/*< Points to the last place that a queued item was read from when the structure is used as a queue. */
		UBaseType_t uxRecursiveCallCount;/*< Maintains a count of the number of times a recursive mutex has been recursively 'taken' when the structure is used as a mutex. */
	} u;
	List_t xTasksWaitingToSend;		/*< List of tasks that are blocked waiting to post onto this queue.  Stored in priority order. */
	List_t xTasksWaitingToReceive;	/*< List of tasks that are blocked waiting to read from this queue.  Stored in priority order. */
	volatile UBaseType_t uxMessagesWaiting;/*< The number of items currently in the queue. */
	UBaseType_t uxLength;			/*< The length of the queue defined as the number of items it will hold, not the number of bytes. */
	UBaseType_t uxItemSize;			/*< The size of each items that the queue will hold. */
	volatile int8_t cRxLock;		/*< Stores the number of items received from the queue (removed from the queue) while the queue was locked.  Set to queueUNLOCKED when the queue is not locked. */
	volatile int8_t cTxLock;		/*< Stores the number of items transmitted to the queue (added to the queue) while the queue was locked.  Set to queueUNLOCKED when the queue is not locked. */
	#if( ( configSUPPORT_STATIC_ALLOCATION == 1 ) && ( configSUPPORT_DYNAMIC_ALLOCATION == 1 ) )
		uint8_t ucStaticallyAllocated;	/*< Set to pdTRUE if the memory used by the queue was statically allocated to ensure no attempt is made to free the memory. */
	#endif
	#if ( configUSE_QUEUE_SETS == 1 )
		struct QueueDefinition *pxQueueSetContainer;
	#endif
	#if ( configUSE_TRACE_FACILITY == 1 )
		UBaseType_t uxQueueNumber;
		uint8_t ucQueueType;
	#endif
} xQUEUE;
本文暂时不需要深入源码,在queue.h的接口已经封装得相当好,无需对细节太过于关注,下面会是对常用接口的使用的总结,如果英文好,直接看源码中的函数注释也是很好的选择。
3 相关概念
3.1 数据结构
队列可以保存有限个具有确定长度的数据单元。队列可以保存的最大单元数目被称为队列的“深度”。在队列创建时需要设定其深度和每个单元的大小。通常情况下,队列被作为 FIFO(先进先出)使用,即数据由队列尾写入,从队列首读出。当然,由队列首写入也是可能的。往队列写入数据是通过字节拷贝把数据复制存储到队列中;从队列读出数据使得把队列中的数据拷贝删除。1 如下图所示;
注意上面提到的数据单元可以是一个charint类型的数,但是相对比较合理的设计是,封装成一个合理的类,或者称之为结构体,可以明确当前数据单元的数据类型,数据来源(来自哪个任务)等等,因为一个队列可以被多个任务进行读取和发送函数,这样就避免了传输数据出现混淆的情况。通常设计是一个队列被多个任务写入数据,然后有一个任务读取,暂时称之为多写一读,反之,多读一写则较少遇到。
3.2 收发数据堵塞
当某个任务试图读或者写一个队列时,其可以指定一个阻塞超时时间,
  • 读取:任务读取数据时,在设置堵塞超时时间内,如果队列为空,该任务将保持阻塞状态以等待队列数据有效。当其它任务或中断服务例程往其等待的队列中写入了数据,该任务将自动由阻塞态转移为就绪态
  • 写入:如果队列被多个任务写入,那么将导致多个任务堵塞以等待队列有效,当队列有效的时候,这些任务中的优先级最高的任务优先进入就绪态。
4 常用函数
FreeRTOS的消息队列常用接口都封装在queue.h中,通过宏定义统一将接口函数的命名风格整理得十分统一;具体如下图所示;
这里有两种需要注意;
  • 任务与任务之间同步:例如图中处的API适用于任务间同步;
    • xQueueSendToFront
    • xQueueSendToFront
    • xQueueSend
    • xQueueOverwrite
  • 任务与中断之间同步:图中②处的API适用于任务于中断间同步,xxxISR()后缀的函数都是FreeRTOS中保证了线程安全的;
    • xQueueSendToFrontFromISR
    • xQueueSendToBackFromISR
    • xQueueOverwriteFromISR
    • xQueueSendFromISR
4.1 创建队列
  • QueueHandle_tQueueHandle_t是一个void类型的指针变量,定义在queue.h中,具体如下;
 * Type by which queues are referenced.  For example, a call to xQueueCreate()
 * returns an QueueHandle_t variable that can then be used as a parameter to
 * xQueueSend(), xQueueReceive(), etc.
typedef void * QueueHandle_t;
基本上每个队列函数都会使用这个变量,这里我们统一称为队列的句柄;
  • xQueueCreate这个函数可以创建一个队列,创建成功则会返回一个队列句柄,如果创建失败则返回NULL,其函数原型是xQueueGenericCreate,具体如下所示;
#define xQueueCreate( uxQueueLength, uxItemSize ) \
xQueueGenericCreate( ( uxQueueLength ), ( uxItemSize ), ( queueQUEUE_TYPE_BASE ) )
xQueueCreate如下所示;
 QueueHandle_t xQueueCreate(
							  UBaseType_t uxQueueLength,
4.2 发送数据
下面都是从任务发送数据到队列,
  • xQueueSendToFront将数据发送至队首,函数声明如下;
 BaseType_t xQueueSendToBack(
								   QueueHandle_t	xQueue,
								   const void		*pvItemToQueue,
								   TickType_t		xTicksToWait
  • xQueueSendToBack将数据发送至队尾,函数声明如下;
 BaseType_t xQueueSendToFront(
							  const void * pvItemToQueue,
  • xQueueSend与xQueueSendToBack入队顺序相同,函数声明如下所示;
BaseType_t xQueueSend(
具体的参数描述如下:
  • xTicksToWait设为0 ,且队列已满,则xQueueSendToFront()与xQueueSendToBack()均会立即返回。阻塞时间是以系统心跳周期为单位的,所以绝对时间取决于系统心跳频率。常量 portTICK_RATE_MS 可以用来把心跳时间单位转换为毫秒时间单位
  • xTicksToWait 设置为 portMAX_DELAY , 并且在FreeRTOSConig.h 中设定 INCLUDE_vTaskSuspend 为 1,那么阻塞等待将没有超时限制。
4.3 接收数据
  • xQueueReceivexQueueReceive()用于从队列中接收(读取)数据单元。接收到的单元同时会从队列中删除。函数声明如下;
 BaseType_t xQueueReceive(
								 void *pvBuffer,
  • xQueuePeekxQueuePeek()也是从从队列中接收数据单元,不同的是并不从队列中删出接收到的单元。 xQueuePeek()从队列首接收到数据后,不会修改队列中的数据,也不会改变数据在队列中的存储序顺。函数声明如下;
 BaseType_t xQueuePeek(
							 void * const pvBuffer,
具体的参数描述如下:
  • uxQueueSpacesAvailableuxQueueSpacesAvailable()用于查询队列中可用的空闲空间数量;函数声明如下;
UBaseType_t uxQueueSpacesAvailable( const QueueHandle_t xQueue );
  • uxQueueMessagesWaitinguxQueueMessagesWaiting()用于查询队列中当前有效数据单元个数;函数声明如下;
UBaseType_t uxQueueMessagesWaiting( const QueueHandle_t xQueue );
4.4 删除队列
  • vQueueDelete用来删除一个队列,直接传入已创建的队列句柄即可,函数声明如下;
void vQueueDelete( QueueHandle_t xQueue );
5 举例
多个任务写入一个任务读取的时候应该怎么做呢?如下图所示2
这里有三个任务,所以为了搞清楚数据来自哪个任务,因此将数据单元封装起来,使用iMeaning表示数据单元的源头,当然这里还是比较简单的应用。
6 总结
本文介绍了FreeRTOS的消息队列比价常用的方法,当然是相对简单的,侧重在了解概念上,需要实际的应用从而加深理解,更加详细已经灵活的应用可以参考FreeRTOS作者撰写的Mastering_the_FreeRTOS_Real_Time_Kernel-A_Hands-On_Tutorial_Guide
赞 4
收藏 3
关注 138
