求助:加拿大要求的燃烧测试Flame Test No. 1-127mm Flame Test
在国内、香港或台湾是否有哪家实验室可以完成此燃烧测试,设备要求原文如下:
1. A tst shield of sheet metal 300mm wide, 350mm deep, and 600mm high, open at the top and front, and 2 rigid support clamps for supporting the test specimen in a vertical position;
2. a Tirrill burner having a bore of 10 +1.6/-0mm and a length of 100+5/-0mm above the primary-air inlet.
3. a 20 degree angle block for supporting the burner;
4. a supply of bottled, technical grade methane gas of approx. 37MJ/m3 at normal pressure with a suitable regulator and meter for uniform gas flow
测试火焰要求原文如下:
the height of the flame with burner vertical shall be adjusted to approx. 127mm with an inner blue cone approx. 38mm high, producing a temp. of 950 +/-50 degree at the tip of inner blue cone at a gas pressure of 76mm water column.
甚感烦恼!想确定怎样一种塑胶厚度最合适通过此测试,避免设计太厚浪费材料。
我们是在申请toy transformer cUL认证时,遇到此难题的,各位GG,JJ,DD,MM有此经验者,能否提供相关的信息。选用哪种塑胶?什么厚度比较适合?
全部回复(3)
有人可以帮忙吗?自己先顶顶!
tigerzen
@pwong03492
有人可以帮忙吗?自己先顶顶!
怎么没有人回答?!!!顶顶顶......
我现在也遇到同样的问题!求助各位做过的大虾帮忙了!!! 谢谢!...
@tigerzen
怎么没有人回答?!!!顶顶顶......我现在也遇到同样的问题!求助各位做过的大虾帮忙了!!!谢谢!...
我顶一下啦500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/38/1140425139.gif');}" onmousewheel="return imgzoom(this);">
